An attempt to allocate resouces to manage the processing of a reply to a transmitted conduit message failed. This may be the result of a network event that is affecting the system CPU utilization.
The system is low on memory resources. The configuration should be reduced in scale or complexity in order for the system to continue operating correctly.
Error
An attempt to allocate callback resources associated with a conduit message for slot %slotNum%, conduit type %conduitType%, pipe %pipe%, and conduit # %conduitNum% failed.
| Name | Type |
| slotNum | uInt |
| conduitType | String |
| pipe | String |
| conduitNum | uInt |
